my plex is working outside my local network but external access is disabled.
How to disable it I want it to only work on the local network
Would you mind elaborating what exact option is disabled and how you do access your server outside your home network?
If you have Settings > [Server Name] > Remote Access disabled, that should mean nobody outside your home network can access your server (exceptions might apply if you don’t have a router of your own or one that’s configured in bridge-mode – similarly VPNs can mess up what’s considered local vs. remote).
I already did this but when I open the app outside my network the movie works
What movie (e.g. a movie hosted on your personal PMS within your home network vs. content from Plex Online Media Sources or another streaming service linked in Discover)?
What particular Plex app are you using? Any VPN or other setup otherwise exposing your home network?
yes PMS movie guys on my home network. app store plex app
Do you run any kind of VPN software on your phone that connects you automatically into your home network?
Stream something from your server remotely (phone on mobile network, etc.).
Monitor the stream via Plex Dashboard → Now Playing + Expanded View.
Is the connection Local, Remote, or Indirect?
If indirect, it is using Plex Relay, a fallback for when remote access is not available. The stream is tunneled through a server at Plex and is limited to 1 Mbps (2 Mbps w/ Plex Pass). You can disable Plex Relay in Settings → Network.
If the connection is Local or Remote, then something else is going on.
