How to enable silence compression
How do I enable silence compression for audio in a library that has store track progress enabled?
you should see additional actions in the player for things played out of that library.
I’m not seeing it on Android or desktop.
just checked and it showed up here. try enabling Long Form controls in experience > player settings?
It was the long form controls, thank you!
