Hi all,
I have an Android STB (R-Box Pro) and Plex for Android is running on top of it.
The remote for the box has number keys on it.
However, pressing the number keys on the remote has no effect.
Instead, I need to go: up-left-down … you get it.
Is it possible to enter the pin with the pin with the hardware number buttons on the remote?
Is there some configuration for this?
Thanks !
