How to have posters in landscape orientation?
Hi, is there any way for a custom agent to display a library’s posters in landscape orientation? My agent is using Agent.Movies, but the same happens with Agent.TV_Shows of course.
The only way I have had landscape posters work is by creating a library using the built-in agent “Personal Media”/Other Videos, but of course that makes my metadata agent not do its job ideally; I want metadata just from my own agent. (And if I add contributes_to = ['com.plexapp.agents.none', 'com.plexapp.agents.localmedia'] to plugin and create new library first as personal media, and then change to my own agent, I get landscape posters for a while, but then it reverts back eventually/very buggy workaround that’s obviously unintentional)
So how can I change the code on my metadata agent to behave similar to “Personal Media”? Any real way?
Thank you!
