Need help with the above as it is not listed in the built-in app store. Anyone has any luck with this?
Get in touch with Anker support and tell them you need to access the Play Store. They will give you a code to beta firmware which will enable access to the Google Playstore which has Plex available.
The beta is Gold Master so perfectly ok to use.
Working great on our Capsule.
Also gives you access to the huge number of apps on the Play Store
You could also install Kodi which is on the Aptoide Store and use the Plex add on for Kodi.
Another option
Can you side load the apk?
Too bad, I see you don’t have a Plex pass…
I’ve just picked up a Nebula Capsule and installed Plex from the built-in Aptoide App Store but when I run it, I’m told I need a plex pass? is this right?
