Does anyone know how to install custom plugin on a Synology NAS? I need to copy a “bundle” to my Synology and I do not know how to get the files to the Plex installation folder.
Niles
Niles
Hi there,
I want to install the pelisalacarta-plex-4.0.5 plugin to watch spanish TV.
I copied to to the mentioned locaton /volume1/Plex/Library/Application Support/Plex Media Server/Plug-ins
It has got the right name pelisalacarta.bundle (next folder is contents with a “s” at the end, …)
I hoped to find the Pluin under Channels but it do not show up.
I also cahnged the permissions to “user” (group) an “plex” (user) for main folder and all subfolders with read, change and execute permissions. Restarted Plex, too.
Any ideal for me?
Thanks.
Hi! I copied the podnapisi folder into the volume1/Plex/Library/Application Support/Plex Media Server/Plug-ins, restarted plex but I can’t find the option. Any ideas?
Thanks in advance.
@CRISTONDA You may also try Sub-Zero. You will find it on the official channel repository (More… / Metadata Agents). It’s an evolution of podnapisi.
Thank you !!
