I did not find anywhere to install it.
Should I download it first? But I did not find anyplace to allow you to select local plugin files to install.
Is it under Channels tab on Plex Server settings?
All information regarding installation is in the first post of the release thread over here.
I am using Nas Plex Media Server. Is it different from PC-based version?
I cannot find Application Support under Library tag.
is plugin available for Nas-based Plex Media Server?
You need to locate your Plex data directory based on your device.
Hi there, the link seems to be broken
SubZero is installed like any other 3rd party plugin:
https://support.plex.tv/articles/201187656-how-do-i-manually-install-a-plugin/
Easiest way follow this smarthomebeginner tutorial
