i am a newbie to plex, but i really like it. Thanks here to the developers for the great work.
I am trying different things, how to handle movies, shows, …
How would it be possible to join some files with the same filename and a scene1, scene2, … at the end of the filename ?
Is it possible to joain the under one film with one cover ?
Thanks a lot
Charlie
Hi Charlie!
You can stack multi-part movies. Have a look at the wiki for info on this: http://wiki.plexapp.com/index.php/PlexNine_PMS_Naming_Guide#Stacked_Files
Hi Sander,
wow, what a fast reply, thanks a lot.
Ok, that would be a possibility.
Would be there another way to customize the settings,how plex handle this and which files plex joins ?
For example: This works with pt1, pt2-files, and also iwth cd1, cd2 Files.
So somewhere perhaps i can configure with what files plex should join the files.
So i don’t have to rename all files.
Ok, by the way, there are some utilities for batch-renaming, i know.
Charlie
