How to load actor images from local disk?
For some tv series which don’t find any metadata from agent,
I collect metadata and images in localdisk.
Then I can see poster and fanart images but not for cast images(+ metadata).
How can I import metadata for cast list from localdisk with images?
Or, is it possible to import local actor images into plex by create an custom agent?
Not possible in Plex, in a default installation.
You can try to install the .nfo importer agents
and create .nfo files for these shows.
But I am not 100% positive that this custom agent is supporting the import of actor pictures.
Thank you for your reply.
I will start from that nfo agents.
