How to refresh metadata with new posters and art?
Server Version#: 1.30.0.6442
Basic Plex Server, running on Windows 11. Lately my MOVIES library is starting to show a movie screenshot of that movie for it’s poster art. Basically a random picture from the movie, which could be anything. How would I refresh that metadata to start changing them from a ugly screenshot from the movie to the nice color artwork. I’m guessing it has something to do with the AGENTS. I just don’t want to clicking on functions that are not needed or would take hours upon hours to complete. Thank you, I appreciate the guidance.
Not exactly sure what you experience and if refreshing metadata will fix this.
You should be able to trigger a refresh from an individual item’s context menu (no need to refresh the entire library).
Thanks for replying. I think the issue is every time in settings I select AGENTS is always reverts back to PERSONAL MEDIA and unchecks THE MOVIE DATABASE. I want the metadata to be pulled from TMD, not personal. I assume that is what controls what kind of metadata is grabbed. I wish it would just stick on the settings I selected. The Movie Database, and NOT personal media.
What exactly have you configured as agent in the advanced options of that library?
From the library’s context menu: > Manage Library > Edit...Advanced > Agent?
I assume this is an actual Movie library – not an Other Video type one?
I just checked and it did refresh the artwork and finally started to use real poster art and not just images from the media file. I went here and made changes to make sure it was on The Movie Database. Few days later I’m sure The Movie Database will be unselected for some reason.
Check the library options – the settings in your screenshots only apply if your library is set to use one of the legacy agents.
3 dots next to the library → Manage Library → Edit → Advanced
What does it say here?
