How to report quality of movies ?
Hi, is it possible to have a report of movies in Plex library separated in quality ? I mean video resolution: 576p, 720p (HD), 1080p (Full HD).
I need it to see which movies should be upgraded to 1080p (native resolution of my LG TV OLED).
Thx, regards.
There are filters available in the Movie Libraries and you can sort them visually.
If you are looking for an actual “Report” in the stand alone sense of the word… try using Plex2CSV a great tool by @dane22 that will extract Media Library information to an Excel spreadsheet. I use it often.
Great!!! The “Resolution” filter is exactly what I was searching for, actually I don’t need the Plex2CSV but I’ll take a look.
Thank you very much Plexhilarated !!!
