Although I can see the “DVR SCHEDULE” for next month or so, where can I see ALL scheduled events to edit them? If a series that I’m recording is on hiatus, I want to see that I still have them enabled for recording when they come back.
Are you in the Plex Web client when looking at the “DVR Schedule”? If so, then look to the right of where scheduled recordings are listed by date, and there should be a “Recording Priority” section. That not only lets you set the recording priority for when there are conflicts, it also shows all series recordings that you have scheduled. If the series has a scheduled recording, but there are no upcoming episodes, it will note that.
Thanks! Actually I was using PMP, but I found the Recording Priority there. I’m puzzled though because I see duplicates of some of the series. They have the same name but one says “No upcoming airings” and the other shows a date&time. There’s no way to find out more details about the item? Which one to delete? How does this happen?
Did you migrate from the"old" EPG to the new on this instance a couple months ago? One possiblity is that one recording is for the old EPG and would never show any upcoming recordings.
Edit: You should be able to click on these items in the recording priority to bring up the series recording for edit. Take a look and see if it shows anything helpful for you. I deleted all old series recordings from the old EPG before I migrated, so don’t have a similar situation to investigate in detail.
