How to see transcoding on plexdash
I have the Plexdash app on my phone, which shows which movies are playing, but how can I tell if my NAS is transcoding or using DirectPlay?
I cannot currently verify. From older posts, you should be able to switch the view to list enhanced information.
Yes, if I click on the extended view, it’s there. Thanks, the solution was simple, haha.
