How to sync watched data between two servers on same account
I have a dual boot computer between windows 10 and OS X. I have Plex and my libraries loaded on both. I don’t want to have to switch from one to the other when I want to watch Plex. But what I watch in one server does not update to the other server. Is there any setting to help these two servers sync under the same user?
Thanks.
Brian
You can use the Trakt plugin. It is no longer officially supported, like all other plugins, but it still works quite well and can be installed manually. I use it to sync watched status between two Plex servers and two Emby servers. It works very very well.
Thanks for the reply! Is there a link to instructions on how to install it?
Brian
If the plugin doesn’t work there are a abunch of scripts that do the same thing. I use https://github.com/Taxel/PlexTraktSync
It works great.
