Server Version#:3.95.2
Player Version#: 1.161.1.1291
These are the 2 version #s I found…don’t know which is which.
I have a Library set up for a TV series with lots of episodes. Most everything seems to be showing up correctly, but the Pilot episode is 2 1-hr shows and ran before Season 1. The source file showed these 2 files as Season00, Episode00, part 1 and part 2. When I put them in Plex Library, they show up as a duplicate S00E00 episode. I can watch part 1 but cannot watch part 2 as it is stacked with part 1. How can I separate this douplicate episode into it’s 2 single episdoe parts?
Thank you so much, NewPlaza. I never would never have none hot to begin doing a search of PLEX to find these files. I’m making file PDFs so I always know how to fix this problem when I run across it again.
Yeah, the articles are impossible to find sometimes.
What really drives me up the wall and the dev’s don’t want to acknowledge is how the articles are collapsed and it makes it impossible to do a find(Ctrl-F) https://support.plex.tv/articles/
Sorry to report that following the directions did not solve the PLEX library errors. I have screen shots available but I don’t see a way to attach them. I still show 2 copies of S01E01 which is actually parts 1 and 2 of the pilot (S01E00)…all of the following Season 01 are correctly named and numbered. The Specials folder has S01E00, part 1 as S00E00, and S01E00, part 2 is missing altogether. All the following episodes in Specials have incorrect titles and numbers, and 2 files in the source folder are also missing! Things are all messed up…still.
Thanks, NewPlaza for the post. I did a metadata reset and that did fix one of my problems, I did some revising of my folder/file descriptions so I’m not sure which remedy worked, but, Now the only problem I have is that a 2-part episode is showing up as a double, single episode. Hope the following screenshots help.
Not necessary to “stack” the two files, since they are listed as 2 episodes on TheTVDB.
/ TV Shows
/ The Rockford Files (1974)
/ Specials
The Rockford Files - s00e01 - Backlash of the Hunter (1).mkv
The Rockford Files - s00e02 - Backlash of the Hunter (2).mkv
Look up your tv show and its episodes at TheTVDB. Particularly when they are categorized as ‘special’ or ‘pre-season’ episodes, or ‘pilot’, or similarly.
That way you’ll know exactly where to put them and which episode and season numbers they should get.
