what do you mean ?
PC is connected to the receiver through HDMI.
I did not use any optical output.
what is audio synchronization mode ? (I see it is set to audio)
I will try the reset configuration now.
what do you mean ?
resetting PMP did not make any difference.
Btw, how can I test if my setup (connection to receiver, cable etc.) supports DTS ?
is there a small player that can play the file with DTS ?
any small DTS file that I can play ?
Use a different player software which supports also passthrough.
Like for instance Kodi.
similar result with Kodi.
so either I have a problem with the connection or settings of the OS, or the receiver does not show DTS symbol.
But I remember that it was showing DTS when I was playing DTS files through my TV’s media player.
Yes, but then it was the TV which was playing the file, not the PC.
So, you know that your AVR is able to decode DTS, but somehow your PC cannot ‘bitstream’ those sound formats.
I had a lot of trouble playing hd audio, in the end I switched to Kodi and use the Plex plugging, if you have tried it what did you select as “output device”? Mine only works if it’s in "WASAPI: HDMI - (your receiver name here)
