So simple question → How do I turn on DTS-HD and Dolby Atmos and other audio formats in Plex Media Player on Windows?
And yess I have a 5.1 receiver. And yes it has DTS-HD and yess the movie what i’m playing supports DTS-HD.
When I play this movie with another player, my denon receiver jumps to DTS-HD. With plex media player it stays in “multi in” mode , because it doesn’'t receive DTS.
I know that in Plex Home Theater you could turn DTS and Dolby on. But this app is not longer supported. If you look for it, you can still find it on google. But I don’t like it.
So where can I find this in Plex Media player app in windows?
I’ve tried Plex media player from the windows 10 Store. And also i’ve tried the desktop version of Plex Media Player. Both of them don’t give DTS or Dolby. It has to be some setting.
Thanks for you replay. Where can I find “Settings - Audio”. Don’t see that? Is it in the windows 10 plex App or the desktop version? Either way, In both programs I don’t see it. If I go to settins, I can choose “web” - “Server” - “User” - “Devices”. In non of those taps I can find anything about “Audio”. The only thing I can find about audio is in; “Web” --> “Player”. And then I can thick some boxes about; “Direct stream” or “Direct play” or Multi-Channel audio boost. But that’s all.
If you are definitely running Plex Media Player, hit Shift+F11 to switch to TV mode.
Thanks again! This was the solution. Quick question; this is only possible in the desktop version plex media player? Isn’t it?
I also gave it a try into the plex media player windows 10 app. But there it doesn’t jump to tv mode with Shift + F11. Or is it an other shortcut than shift + F11?
ok thank you! It’s working great with the plex media player app now. I use my TV as an extend Desktop. So on my TV I’ve launched the plex media player. So when i’m on my sofa, I just turn on my TV, and when I launch my plex application on my phone, I can easily launch my movie and let it play on the connected TV. So everyone can keep using the PC. It’s like a second PC works great! And with dts-hd and everything
According to this answer, I selected all that apply. Enabled specifically DTS.
But the info (i) screen still shows “Setting- DTS (DCA): false”
the movie has a DTS audio stream and I select it on PMP.
Media info confirms it is DTS as following info.
Format : DTS
Format/Info : Digital Theater Systems
Format profile : MA / Core
Codec ID : A_DTS
My receiver is a Yamaha RX-V667 which support DTS.
But, I see that PMP is buffering this movie. Does it mean that it transcodes ?
Even if it is a local file, why does it transcode ?
is DTS supported even if there is transcoding ?
