My movie is in English. I speak English. I have one set of subtitles available also English. I don’t need English subtitles.
My subtitle automatically plays. Every. Freekin. Time.
I can turn it off by going down to the bottom, selecting options, selecting streams, etc. But is there any way to disable all subtitles by default?
Even better… when you are watching an English show that has English subtitles available but you’ve turned them off. Suddenly the characters encounter somebody speaking German. How do you get the English subtitles to pop up but only for the non-english parts?
There is a way you can disable all subtitles. If you want this to be as flawless as possible you will need to make some changes. Will this work for the classic Plex version for Roku… Probably not…
As you can see, SRT track 1 is on and set as the default and will be shown in the movie.
Remember though, the last part of your question relies on you. If you don’t have a subtitle file that only contains the non-English parts of the movie then it won’t work the way you want it to. This of course is for local files you have, not some online source…
I do not use any online sources to automatically pull down subtitles so I do NOT know if subtitles will display for non-English parts…
@NewPlaza I set the video forced subtitle PGS track to Forced and Default and set other subtitle tracks to Off for both Forced and Default but it still defaults to another subtitle track in plex web player. I refreshed the metadata everytime.
@kianrafiee: as referred to in your original thread… tell Plex to analyze the movie after editing the content – this way Plex updates the information about the subtitle being forced.
Reviving this thread to save others time.
I had the same issue, turned out that my Player (Samsung TV) had turned subtitles on at some point.
Though they worked inconsistently though different episodes. Check your local player (Not Plex) settings.
@NewPlaza: Your solution helped me to solve my “always on subtitle” problem. I double checked the mp4 files and for both audio tracks the language setting was “unknown”. I changed it to track 1 = german / track 2 = english and it works perfect.
Also to keep this thread alive but what if I don’t want any subtitles at all for anyone on my server to play them, can I set the server somewhere to NEVER play the subtitles?
Load plex,
Go to your account,
Click on other settings,
Click on “Global Settings”
Adjust to your preferences,
Save settings,
Exit and reload Plex.
Hopefully you will no longer have any subtitles.
