Server Version#: 1.24.3.5033
Player Version#: 4.63.0
So - I’m not a networking person at all. So apologies in advance.
I have a Plex server running on Ubuntu 16.04 LTS. It’s on an Intel NUC. I originally set it up four years back and remote access used to run fine. But while away from home recently I noticed that my videos were ‘blocky’. On checking, I see that my videos are running “indirectly” when accessing them remotely.
I’m not sure when this stopped working as I’ve not been away from home much due to lockdowns, etc.
When I look in Settings, Remote Access, I see “Not available outside your network”.
- Private is set to 192.168.1.xxx.xx : 32400
- Public is set to 185.241.xxx.xxx : 32400
If I go to canyouseeme.org it sees my public IP, but when I type 32400 for the Port to check, it says "Error: I could not see your service on 185.241.xxx.xxx on port (32400).
I tried opening that port using:
sudo ufw allow from 185.241.xxx.xxx to any port 32400 proto tcp.
When I look at the firewall status (ufw status) it shows:
To: 32400/tcp action: ALLOW From: 185.241.xxx.xxx
I’ve tried many different things from manually specifying the public port in the Plex settings, to enabling UPnP in the router, and setting up port forwarding. But nothing seems to work.
When I go to the Remote Access page, it initially shows green for 5 seconds, then goes back to red - Not available outside your network.
Is my problem to do with the error shown on the canyouseeme.org website? How can I change it so that the 32400 port doesn’t produce an error on that site?
Grateful for any guidance. I’m so glad I’m bald; If I wasn’t I’m sure I’d have pulled my hair out by now!
Pretty sure this has come up before. Try searching the forum but from memory don’t think remote access is possible.
