How to use Shield + Plexamp + Android Auto
Server Version#: Shield Server 1.43.2.10687
Player Version#: Android Phone Client 2026.9.0
I have Plex running on an Nvidia Shield Pro 2019. I currently use it basically as an OTA DVR. I have an external SSD connected to the Shield for storage of the recordings.
I also have a large collection of music I ripped with iTunes many years ago, stored on a external hard drive connected to my PC that has been dormant for awhile. I’ve tired of using Amazon Prime Music and Spotify (for a number of reasons), so I thought maybe I could put my old iTunes library back to use, and stream the music files to my car through my Shield, Android phone, and Android Auto. I’m thinking of using PlexAmp, but I don’t really know if it woulld work. Thus I am here for advice.
My first idea was to copy all of the .MP3 files from my iTunes library to an external USB SSD drive and connect it to my phone. Having done that, I could play the music to AA wirelessly using PowerAmp (it plays iTune files just fine), and it worked reasonably well. But I discovered some problems: I don’t like having to plug the drive into my phone all the time with a USB cable, and having to hide it in my car. And when I disconnect the drive from my phone, the phone complains about an improper disconnect and tells me to restart the phone. I really want a minimal-effort way to play music, like I do from the aforementioned streaming services.
Can I take the USB SSD drive and plug it into the open USB jack on my Shield? What’s the proper way to get Plex to recognize the new source of music files and accept them into a library? If I can get remote access working (I’m behind CGNAT and would have to pay for a static IP), will PlexAmp be able to play my music through Android Auto?
I’m not too concerned about organizational issues or stuff like that for now. I usually just play music at random from the streaming sources today (like the old days of FM radio), but I may want to do more in that area once I get it working.
Please let me know if there’s any recommended method to this madness (ha ha). I don’t want to mess up my current Plex setup in the process. Thanks.
Well, I got it working and it was easier than I expected.
First I copied all my old iTunes music files (10K plus) to a USB external SSD. Then I plugged that into the Shield.
Next I went into Plex and created a Music library and pointed it to the SSD folder. Plex immediately began cataloging all my songs.
Next I installed PlexAmp on my phone and got it working in Android Auto in my car.
Then I disabled Remote Access in Plex and disabled Relay as well.
Next I created a free TailScale account and installed TailScale on the Shield and on my Samsung phone to create my “TailNet”. This was surprisingly easy. This would allow me to connect remotely without CGNAT getting in the way, and without requiring me to pay for a static IP.
I took a road trip over the weekend and with TailScale enabled and PlexAmp running in Android Auto, I was able to continuously stream my music (in random shuffle mode) for hours. I was impressed with the sound quality (since my song files were all originally ripped years ago in iTunes Lossless format) and how smoothly PlexAmp displayed coverart, showed album and song titles, and faded from one song to the next perfectly. I was very impressed so far.
I have had only two occasions where PlexAmp failed: Once, when a phone call came in, PlexAmp stopped playing and after I hung up I could not get it to resume again. Another time an appointment reminder alerted on my phone and PlexAmp stopped playing. I can’t remember which was which, but on one of the occasions I got an actual “PlexAmp has crashed” error. On the other occasion I had to reboot my phone to get PlexAmp going again.
Hope this helps anybody reading this thread.
On a few occasions now I’ve been able to listen to music from my Plex server with Tailscale turned OFF. I have remote access turned off in Plex and I have Plex Relay disabled as well. I was surprised PlexAmp kept on playing. Sometimes it plays for quite awhile. Sometimes it stops playing and once I have to turned Tailscale back on it can play again. How is it possible I’m getting my PlexAmp stream without Tailscale?
Why? It is designed to serve as a fallback, if a direct connection is not possible. It should provide sufficient bandwidth for music.
Plexamp will cache songs locally, so it will keep playing without needing a connection back to the server until the cache is exhausted. There is a setting in plexamp on how much cache to use.
I’m behind CGNAT so remote access is not possible natively, which is why I went with a Tailscale setup. That works very well. I can stream my music at full uncompressed quality so the sound quality is quite good. I turned Relay off so PlexAmp wouldn’t try to use it, that’s all.
I kind of had a suspicion this could be what it is doing. That would explain why the amount of playback time varies from one drive to the next. Thanks!
