Htpc wont play live channels but website and firetv does
@hokierulz
(working) i cleared the logs then tested livetv with chrome
chrome working transcode logs.zip (5.0 KB)
(not working) i cleared the logs then tested with htpc
htpc not working trancode logs.zip (5.5 KB)
@5stringdeath i dont watch much live tv as well. but its good for background noise sometimes.
@hokierulz @5stringdeath
i found it yay, and so simple. turn off direct stream. direct play only, and now it dont buffer ether.
Its not a solution. Does not work here. I tried this months ago. That’s how long its been broken.
Do you use IPTV or tuner? And does live tv work on any other devices besides htpc?
I’m willing to bet the real problem is your channel has AAC audio instead of AC3 audio thus why the Windows player is not working when the others are.
