HW Tone-mapping fails since 1.29.1 on Intel J5040
Server Version#: 1.29.2.6364 (Docker)
Player Version#: any
I know there’s a major difference to QuickSync usage now since 1.29.1. But since then, hardware tone-mapping fails with my machine.
Until 1.29.0 everything ran perfectly with manually installed Intel drivers.
Nov 11, 2022 21:15:48.900 [0x7f1f164bab38] ERROR - [Req#100/Transcode/p58htcq9inidsobb8i4dmqfx/b4ab7ade-f1df-4c69-832b-4686f9c5c21d] [Parsed_tonemap_opencl_3 @ 0x7f525d366400] Failed to finish command queue: -5.
Nov 11, 2022 21:15:49.406 [0x7f1f164bab38] ERROR - [Req#125/Transcode/p58htcq9inidsobb8i4dmqfx/b4ab7ade-f1df-4c69-832b-4686f9c5c21d] Error while filtering: I/O error
Nov 11, 2022 21:15:49.406 [0x7f1f164bab38] ERROR - [Req#126/Transcode/p58htcq9inidsobb8i4dmqfx/b4ab7ade-f1df-4c69-832b-4686f9c5c21d] Failed to inject frame into filter network: I/O error
Nov 11, 2022 21:15:49.406 [0x7f1f164bab38] ERROR - [Req#127/Transcode/p58htcq9inidsobb8i4dmqfx/b4ab7ade-f1df-4c69-832b-4686f9c5c21d] Error while processing the decoded data for stream #0:0
Nov 11, 2022 21:15:49.664 [0x7f1f164bab38] DEBUG - Request: [127.0.0.1:48692 (Loopback)] GET /identity (11 live) #122 Signed-in
Nov 11, 2022 21:15:49.665 [0x7f1f1c81bb38] DEBUG - Completed: [127.0.0.1:48692] 200 GET /identity (11 live) 0ms 398 bytes (pipelined: 1)
Nov 11, 2022 21:15:50.431 [0x7f1f1ca58b38] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 517 is 1 (failure)
Nov 11, 2022 21:15:50.431 [0x7f1f1b0e9b38] DEBUG - Streaming Resource: Changing client to use software decoding
Now I get these errors when trying to transcode any HDR video.
I doubt myself as I only read it works with most machines, especially with J4105s. Any guess on the basis of the attached logs?
Plex Media Server Logs_2022-11-11_21-28-25.zip (2.2 MB)
Do you still have the intel-Compute-Runtime drivers manually installed ?
Asking because I’ve successfully tested on a QNAP NAS which didn’t have anything installed.
The CPU there is N5105
[~] # cat /proc/cpuinfo | grep model
model		: 156
model name	: Intel(R) Celeron(R) N5105 @ 2.00GHz
Well I can confirm that HW HDR tone mapping works with 1.29.0. but fails since 1.29.1. Running docker official repo, unraid and J4105 (gemini lake).
I fully expect and concur 1.29.1 had problems.
1.29.1 was incomplete on some processors.
When I spoke with Engineering about it, they were already aware and 1.29.2 would contain the hardware support which was missing in 1.29.1
@premikkoci
I cannot speak to unraid.
The entire (J / N) series , since they’re all Gemini Lake CPUs, work.
We have a few ASUSTOR J4xxx and N5xxx units in our lab in addition to QNAP boxes.
They all work. (which is what’s reflected on our NAS Compatibility Guide now).
The all work in docker too.
I suspect the container and installed drivers.
How difficult is it to -
  1. Stop the existing container
  2. Create a parallel “Test” container, which uses PMS 1.29.2 (public)
  3. Points to the existing /config/Library/Application Support/Plex Media server
This would allow creation of a pure , fresh, container, containing only the Plex drivers with the existing server .
I would gladly help more with unraid if I could figure out how to create a test VM without purchasing their full product
Had to change the topic title as stupid me didn’t realize it’s a J5040.
Sounded like a good idea to uninstall all the drivers first.
So that’s what I did:
sudo vainfo
error: XDG_RUNTIME_DIR not set in the environment.
error: can't connect to X server!
libva info: VA-API version 1.14.0
libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/iHD_drv_video.so
libva info: va_openDriver() returns -1
libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/i965_drv_video.so
vaInitialize failed with error code -1 (unknown libva error),exit
Still the same result though.
I don’t get the point in creating a new container and pointing to the same directory actually.
But I did so, deleted Drivers, Codecs and Cache. Still nothing.
To revert back to 1.29.0 for the time being I’ll have to install the drivers back now…
Edit: No well, it’s using VAAPI now to transcode, which should be alright until I hopefully figure out pretty soon what’s the issue.
Just to be clear: 1.29.2 doesn’t do fallback to VAAPI here either.
I have tried clean installs with every new release and hw HDR tone mapping keeps failing since 1.29.1. Might be related to kernel 5.19.17?
I think unraid offers 14 days trial.
I tried with several kernels - starting from 5.17.0 via 5.18.0 and 5.19.x to 6.0.8 now. None of them made hw tone-mapping work.
Please stop with the the kernels game? Run the default kernel, which has ALL the right runtime libraries…
Changing just the kernel will screw the pooch because this will work with older kernels too
This is GeminiLake – Kernel 5.10 is more than enough.
AlderLake / RaptorLake want newer kernels.
model		: 156
model name	: Intel(R) Celeron(R) N4505 @ 2.00GHz
model		: 156
[~] # uname -a
Linux QNAP-TS262 5.10.60-qnap #1 SMP Wed Dec 29 01:54:08 CST 2021 x86_64 GNU/Linux
That’s alright. But reverting to the standard kernel for Ubuntu 22.04, which is 5.15, will not make a difference either.
I tested on Ubuntu 20.04 and 22.04. It does work.
Looking at your logs shows the server is accessing the hardware successfully
Nov 11, 2022 21:15:41.397 [0x7f1f192feb38] DEBUG - [Req#c4/Transcode] [FFMPEG] - Format 0x56323234 -> yuv440p.
Nov 11, 2022 21:15:41.397 [0x7f1f192feb38] DEBUG - [Req#c4/Transcode] [FFMPEG] - Format 0x50343434 -> yuv444p.
Nov 11, 2022 21:15:41.397 [0x7f1f192feb38] DEBUG - [Req#c4/Transcode] [FFMPEG] - Format 0x33434d49 -> unknown.
Nov 11, 2022 21:15:41.397 [0x7f1f192feb38] DEBUG - [Req#c4/Transcode] [FFMPEG] - Format 0x30313050 -> p010le.
Nov 11, 2022 21:15:41.397 [0x7f1f192feb38] DEBUG - [Req#c4/Transcode] [FFMPEG] - Created surface 0.
Nov 11, 2022 21:15:41.397 [0x7f1f192feb38] DEBUG - [Req#c4/Transcode] [FFMPEG] - Direct mapping possible.
Nov 11, 2022 21:15:41.399 [0x7f1f192feb38] DEBUG - [Req#c4/Transcode] TPU: hardware transcoding: final decoder: vaapi, final encoder: vaapi
Nov 11, 2022 21:15:41.400 [0x7f1f192feb38] DEBUG - [Req#c4/Transcode/JobRunner] Job running: EAE_ROOT=/tmp/pms-c1365533-c6c7-447e-a4ff-fb2ec0159fc4/EasyAudioEncoder FFMPEG_EXTERNAL_LIBS='/config/Library/Application\ Support/Plex\ Media\ Server/Codecs/c4efa15-4387-linux-x86_64/' LIBVA_DRIVERS_PATH=/usr/lib/plexmediaserver/lib/dri OCL_ICD_VENDORS="/config/Library/Application Support/Plex Media Server/Cache/CL-ICDs" X_PLEX_TOKEN=xxxxxxxxxxxxxxxxxxxx4a5d-975a-9ddaa16185bd cl_cache_dir="/config/Library/Application Support/Plex Media Server/Cache/Shaders/icr-9-linux-x86_64/" "/usr/lib/plexmediaserver/Plex Transcoder" -codec:0 hevc -hwaccel:0 vaapi -hwaccel_fallback_threshold:0 10 -hwaccel_output_format:0 vaapi -hwaccel_device:0 vaapi -codec:2 eac3_eae -eae_prefix:2 p58htcq9inidsobb8i4dmqfx_ -analyzeduration 20000000 -probesize 20000000 -i "/media/HDD6/Filme/Blond (2022) {imdb-tt1655389}/Blond (2022) {imdb-tt1655389} - 1080p WEB h265 [DMPD].mkv" -filter_complex "[0:0]hwupload[0];[0]scale_vaapi=w=1920:h=1080:format=p010[1];[1]hwmap=derive_device=opencl[2];[2]tonemap_opencl=tonemap=mobius:format=nv12:m=bt709:p=bt709:r=tv[3];[3]hwmap=derive_device=vaapi:reverse=1[4];[4]hwupload[5]" -map "[5]" -codec:0 h264_vaapi -b:0 20000k -r:0 24 -force_key_frames:0 "expr:gte(t,n_forced*1)" -filter_complex "[0:2] aresample=async=1:ocl='stereo':rematrix_maxval=0.000000dB:osr=48000[6]" -map "[6]" -metadata:s:1 language=eng -codec:1 aac -b:1 256k -f dash -seg_duration 1 -dash_segment_type mp4 -init_seg_name 'init-stream$RepresentationID$.m4s' -media_seg_name 'chunk-stream$RepresentationID$-$Number%05d$.m4s' -window_size 5 -delete_removed false -skip_to_segment 1 -time_delta 0.0625 -manifest_name "http://127.0.0.1:32400/video/:/transcode/session/p58htcq9inidsobb8i4dmqfx/b4ab7ade-f1df-4c69-832b-4686f9c5c21d/manifest?X-Plex-Http-Pipeline=infinite" -avoid_negative_ts disabled -map_metadata -1 -map_chapters -1 dash -map 0:5 -metadata:s:0 language=eng -codec:0 ass -strict_ts:0 0 -f segment -segment_format ass -segment_time 1 -segment_header_filename sub-header -segment_start_number 0 -segment_list "http://127.0.0.1:32400/video/:/transcode/session/p58htcq9inidsobb8i4dmqfx/b4ab7ade-f1df-4c69-832b-4686f9c5c21d/manifest?stream=subtitles&X-Plex-Http-Pipeline=infinite" -segment_list_type csv -segment_list_size 5 -segment_list_separate_stream_times 1 -segment_format_options ignore_readorder=1 -segment_list_unfinished 1 -fflags +flush_packets "sub-chunk-%05d" -start_at_zero -copyts -vsync cfr -init_hw_device vaapi=vaapi:/dev/dri/renderD128 -filter_hw_device vaapi -y -nostats -loglevel quiet -loglevel_plex error -progressurl http://127.0.0.1:32400/video/:/transcode/session/p58htcq9inidsobb8i4dmqfx/b4ab7ade-f1df-4c69-832b-4686f9c5c21d/progress
Nov 11, 2022 21:15:41.400 [0x7f1f192feb38] DEBUG - [Req#c4/Transcode/JobRunner] Jobs: Starting child process with pid 517
Nov 11, 2022 21:15:41.406 [0x7f1f164bab38] DEBUG - Request: [127.0.0.1:60276 (Loopback)] PUT /video/:/transcode/session/p58htcq9inidsobb8i4dmqfx/b4ab7ade-f1df-4c69-832b-4686f9c5c21d/progress?status=startup (11 live) #b9 Signed-in Token (alexf00) (range: bytes=0-)
Nov 11, 2022 21:15:41.406 [0x7f1f1c81bb38] DEBUG - Completed: [127.0.0.1:60276] 204 PUT /video/:/transcode/session/p58htcq9inidsobb8i4dmqfx/b4ab7ade-f1df-4c69-832b-4686f9c5c21d/progress?status=startup (11 live) 0ms 203 bytes (pipelined: 1) (range: bytes=0-)
Nov 11, 2022 21:15:41.412 [0x7f1f1628bb38] DEBUG - Request: [127.0.0.1:60276 (Loopback)] PUT /video/:/transcode/session/p58htcq9inidsobb8i4dmqfx/b4ab7ade-f1df-4c69-832b-4686f9c5c21d/progress?status=startup (11 live) #c8 Signed-in Token (alexf00) (range: bytes=0-)
Nov 11, 2022 21:15:41.412 [0x7f1f1c618b38] DEBUG - Completed: [127.0.0.1:60276] 204 PUT /video/:/transcode/session/p58htcq9inidsobb8i4dmqfx/b4ab7ade-f1df-4c69-832b-4686f9c5c21d/progress?status=startup (11 live) 0ms 203 bytes (pipelined: 2) (range: bytes=0-)
Nov 11, 2022 21:15:41.413 [0x7f1f164bab38] DEBUG - Request: [127.0.0.1:60276 (Loopback)] PUT /video/:/transcode/session/p58htcq9inidsobb8i4dmqfx/b4ab7ade-f1df-4c69-832b-4686f9c5c21d/progress?status=opening (11 live) #c9 Signed-in Token (alexf00) (range: bytes=0-)
Nov 11, 2022 21:15:41.413 [0x7f1f1c618b38] DEBUG - Completed: [127.0.0.1:60276] 204 PUT /video/:/transcode/session/p58htcq9inidsobb8i4dmqfx/b4ab7ade-f1df-4c69-832b-4686f9c5c21d/progress?status=opening (11 live) 0ms 203 bytes (pipelined: 3) (range: bytes=0-)
Nov 11, 2022 21:15:41.416 [0x7f1f1628bb38] DEBUG - Request: [127.0.0.1:60276 (Loopback)] PUT /video/:/transcode/session/p58htcq9inidsobb8i4dmqfx/b4ab7ade-f1df-4c69-832b-4686f9c5c21d/progress?status=opened (11 live) #ca Signed-in Token (alexf00) (range: bytes=0-)
Nov 11, 2022 21:15:41.416 [0x7f1f1c81bb38] DEBUG - Completed: [127.0.0.1:60276] 204 PUT /video/:/transcode/session/p58htcq9inidsobb8i4dmqfx/b4ab7ade-f1df-4c69-832b-4686f9c5c21d/progress?status=opened (11 live) 0ms 203 bytes (pipelined: 4) (range: bytes=0-)
Nov 11, 2022 21:15:41.416 [0x7f1f164bab38] DEBUG - Request: [127.0.0.1:60276 (Loopback)] PUT /video/:/transcode/session/p58htcq9inidsobb8i4dmqfx/b4ab7ade-f1df-4c69-832b-4686f9c5c21d/progress/stream?index=0&id=0&codec=hevc&type=video (11 live) #cb Signed-in Token (alexf00) (range: bytes=0-)
Nov 11, 2022 21:15:41.416 [0x7f1f1c81bb38] DEBUG - Completed: [127.0.0.1:60276] 200 PUT /video/:/transcode/session/p58htcq9inidsobb8i4dmqfx/b4ab7ade-f1df-4c69-832b-4686f9c5c21d/progress/stream?index=0&id=0&codec=hevc&type=video (11 live) 0ms 195 bytes (pipelined: 5) (range: bytes=0-)
Nov 11, 2022 21:15:41.417 [0x7f1f1628bb38] DEBUG - Request: [127.0.0.1:60276 (Loopback)] PUT /video/:/transcode/session/p58htcq9inidsobb8i4dmqfx/b4ab7ade-f1df-4c69-832b-4686f9c5c21d/progress/stream?index=1&id=0&codec=eac3&type=audio (11 live) #cc Signed-in Token (alexf00) (range: bytes=0-)
Nov 11, 2022 21:15:41.417 [0x7f1f1c618b38] DEBUG - Completed: [127.0.0.1:60276] 200 PUT /video/:/transcode/session/p58htcq9inidsobb8i4dmqfx/b4ab7ade-f1df-4c69-832b-4686f9c5c21d/progress/stream?index=1&id=0&codec=eac3&type=audio (11 live) 0ms 195 bytes (pipelined: 6) (range: bytes=0-)
Nov 11, 2022 21:15:41.417 [0x7f1f164bab38] DEBUG - Request: [127.0.0.1:60276 (Loopback)] PUT /video/:/transcode/session/p58htcq9inidsobb8i4dmqfx/b4ab7ade-f1df-4c69-832b-4686f9c5c21d/progress/stream?index=2&id=0&codec=eac3&type=audio (11 live) #cd Signed-in Token (alexf00) (range: bytes=0-)
Nov 11, 2022 21:15:41.417 [0x7f1f1c81bb38] DEBUG - Completed: [127.0.0.1:60276] 200 PUT /video/:/transcode/session/p58htcq9inidsobb8i4dmqfx/b4ab7ade-f1df-4c69-832b-4686f9c5c21d/progress/stream?index=2&id=0&codec=eac3&type=audio (11 live) 0ms 195 bytes (pipelined: 7) (range: bytes=0-)
Nov 11, 2022 21:15:41.439 [0x7f1f1628bb38] DEBUG - Request: [127.0.0.1:60276 (Loopback)] PUT /video/:/transcode/session/p58htcq9inidsobb8i4dmqfx/b4ab7ade-f1df-4c69-832b-4686f9c5c21d/progress/streamDetail?index=0&id=0&codec=hevc&type=video&profile=Main%2010&width=1920&height=1080&interlaced=0&sar=1:1&level=120&frameRate=24.000&disp_default=1 (11 live) #ce Signed-in Token (alexf00) (range: bytes=0-)
Nov 11, 2022 21:15:41.439 [0x7f1f1c618b38] DEBUG - Completed: [127.0.0.1:60276] 200 PUT /video/:/transcode/session/p58htcq9inidsobb8i4dmqfx/b4ab7ade-f1df-4c69-832b-4686f9c5c21d/progress/streamDetail?index=0&id=0&codec=hevc&type=video&profile=Main%2010&width=1920&height=1080&interlaced=0&sar=1:1&level=120&frameRate=24.000&disp_default=1 (11 live) 0ms 195 bytes (pipelined: 8) (range: bytes=0-)
Nov 11, 2022 21:15:41.439 [0x7f1f164bab38] DEBUG - Request: [127.0.0.1:60276 (Loopback)] PUT /video/:/transcode/session/p58htcq9inidsobb8i4dmqfx/b4ab7ade-f1df-4c69-832b-4686f9c5c21d/progress/streamDetail?index=1&id=0&codec=eac3&type=audio&language=ger&channels=6&layout=5.1%28side%29&sampleRate=48000&disp_default=1 (11 live) #cf Signed-in Token (alexf00) (range: bytes=0-)
The problem is elsewhere.
What is this being played on?
Oh my god. I’m kinda sorry actually.
Changing the kernel back to 5.15.0-52-generic (automatically installed by the OS) did the trick.
I don’t know why I updated in the first place, obviously shouldn’t have done that.
So this case is solved.
Thanks a lot.
Your logs are all over the map.
One attempt it gets hardware, the next it doesn’t.
The log is from the 6.0.8 kernel
Please go back to the supported 5.15 kernel
3 posts were split to a new topic: HW tonemapping issue - Unraid + Docker?
I use Unraid “as main System” on Bare Metal and “Inside Unraid” a Plex Docker.
Unraid Supports Docker “nativ”.
I think you can use Virtual Box on your PC and Install Unraid as a VM, but the "Problem is here that you need to create a Virtual Boot Stick to Boot Unraid (Unraid Boots in to the RAM ).
If you want write me a Privat Message and i can Share my screen and we can do some Testing together if this helps.
@ChuckPa
have you been able to install and test unraid in the meantime?
No.
Either I’m a complete idiot about making a boot thumb drive or Unraid can see the ESXi hypervisor.
Why they don’t offer an iso is beyond my understanding.
@ChuckPa I guess the license is bound to a usb drive. Are you able to access your esxi machine physically?
Yes, it’s the NUC here. Since this pic, I’ve added another.
The USB is the ESXi boot
@ChuckPa Perhaps this guide might help you.
Thanks for all your efforts.
Thank you for that.
He shows a very important step which I’ve not gotten past.
  1. Download the tool
  2. Insert thumb drive
  3. Write to USB
For me, The thumb drive is always “Incompatible”.
Thoughts?
What’s the formatting for Windows? Blank? NTFS? FAT32 ?
