what does vainfo return please?
Apologies did not see a reply notice come in. For a little more info, Iâm running a 9700k if that matters.
vainfo output below. Notice- This is run remotely thorugh ssh, if it should be run via a different method, let me know.
[xxxx@xxxxx ~]$ sudo vainfo
error: XDG_RUNTIME_DIR not set in the environment.
libva info: VA-API version 1.3.0
libva info: va_getDriverName() returns -1
libva error: va_getDriverName() failed with unknown libva error,driver_name=(null)
vaInitialize failed with error code -1 (unknown libva error),exit
Thanks for getting back to me.
The information you show tells me it doesnât know whatâs happening.
Not many Linux kernels have support for the -9xxx CPUâs i915 yet.
Linux 4.15.0-39-generic #42-Ubuntu SMP Tue Oct 23 15:48:01 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
error: canât connect to X server!
libva info: VA-API version 1.1.0
libva info: va_getDriverName() returns 0
libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/i965_drv_video.so
libva info: Found init function __vaDriverInit_1_1
vainfo: intel_memman.c:38: intel_memman_init: Assertion âintel->bufmgrâ failed.
Aborted
Known Intel driver problem.
We have to wait for it to be fixed.
Someone mentioned that the Mainline builds should support the latest iGPUs: https://wiki.ubuntu.com/Kernel/MainlineBuilds
v4.20.3 kernel currently.
Please allow me to show:
This is not part of Plex. This is either manually compiled or a distroâs add-on package.
Use 8700, got the same error message here,wait for the answer.
Intel has migrated to the newer iHD driver.
The Plex transcoder is being updated.
I am not fully briefed on details but understand this problem being handled in the upcoming transcoder update.
Thanks for the update. Glad to hear there might be a solution in the near future.
Are there any timeframes for this?
Thanks in advance!
No hard date yet.
My latest knowledge is the Transcoder update is being regression tested now.
Thanks for that .
Hope to see this implemented in a release soon
Intel core i9 9900k waiting eagerly.
Kind regards
We would be willing to help test if needed!
There will be forum beta thread
Are there any updates for this? Iâm currently running a fedora server 30 with a 5.1.17 kernel, a i5-9600k, with a ARock 390 based chipset. I donât know if this helps but here is the vainfo output.
vainfo
libva info: VA-API version 1.4.1
libva info: Trying to open /usr/lib64/dri/i965_drv_video.so
libva info: va_openDriver() returns -1
Unfortunately No.
I have bookmarked all the main threads on this topic.
When I have something to share, I will come around and post.
The current status is standard regression testing cycle. Transcoding video is complex. Plexâs transcoding is more than vanilla FFMPEG, hence the extra effort involved.
Iâm following this thread and the others as well, I know its difficult to give an ETA but this issue has been reported end of 2018 and we are past mid 2019 now. People building new servers now are mostly getting the latest 9xxx CPUs thinking HW transcoding works while its not. While I donât mind it myself (i9 9900K non hw transcoding works fine) others will be disappointed, maybe post a sticky about it that hw transcoding on 9xxx CPUâs, on Linux without 5.0 kernel is not working at moment? And maybe, just maybe a ETA on a beta so others can help with expediting? Iâm happy test on a Docker instance which only I use.
I know everyone is gnashing at the bit to move forward.
When I signed in this morning, I saw more advancements.
Canât tell you what I saw but I will say two of the most wanted are now enabled.
This is good.
I canât give an ETA because Iâm not in Engineering. Iâm Customer Support and Test Engineering (aka. QA) with additional duties to Packaging (a facet of Engineering/Production)
Nothing personal against you Chuck, at least youâre on it with keeping us up to date, thatâs better than no response like some other threads here for common and long running issues.
