HW trancoding not work on i5-9600k
As I see more, I keep reporting.
HEVC 2160p testing going on now. Looking good.
You know if you need a Guinea pig field test this…
Has there been any updates on when this will become available?
no updates other than what I see them testing and fixing.
No date yet as to when it might be released
Does hardware transcoding work under Windows on i5-9600K gpu processors?
I don’t know. I can only suggest you search but I don’t think the two can be compared because Linux uses VA-API and Windows uses DXVA2 - two entirely different mechanisms.
This does not work on Windows does it? Last time I tried it kept crashing PMS. I’m using a 9700K.
Any updates on this for windows or linux?
whoa whoa! Does this update include support for the i9 9xxx series iGPUs in the plex transcoder on Linux?
yes, it does and all reports I’ve seen are that it works as advertised.
Hey mate when can we expect this on a mainstream release?
If this follows the last major update, it will be a few weeks but I can’t predict Engineering’s schedule and I’ve not been informed of their plans.
So far, it seems to be working well. I suspect they would like to be certain the new HW codecs (VC-1 etc) are solid before releasing mainstream.
Thanks :slight_smile:
It indeed does support 9xxx CPU’s. I have it running right now on a i5-9600k running Fedora 30 Server. I don’t imagine there would be any issues running on a i9-9900k that are not inherent to running a beta release. Yesterday I had 7 streams, 6 UHD and 1 HD, running from this server all of them being hardware transcoded.
The only issues that I’ve seen with it so far are some minor pixilation issues with that on some systems. There seems to be more issues with video in the web viewer. Seek issues and some cases of heavy pixilaiton while viewing.
Over all I’m very pleased with it.
New version that supports hardware on a i5-9600K, 1.1.17, came down through normal channels the other day. So far so good. No issues.
Guys any idea what happened to hardware transcoding?
With the latest update all of a sudden it’s not working again…
DEBUG Logs please? (recreating the problem)
Could you please guide me on how to get that for you?
Plex Media Server Logs_2019-10-04_18-20-30.zip (7.5 MB)
Would this work ?
