- Settings - Server - General - Show Advanced
- Make certain DEBUG logging box is checked
- Make certain VERBOSE logging box is not checked
- SAVE Changes if you had to change anything.
- Go back to the home display
- Start Playback.
- Let it play for 15 seconds
- Stop Playback
- Wait 30 seconds for logs to flush to disk
- Settings - Server - Troubleshooting - Download Logs
- Drag & Drop the ZIP file it gives you here.
- Allow the upload to complete before pressing
Reply
Attached above
It would have saved a bit of time to know you’re in Docker.
I’m not seeing and reference to HW transcoding detection
- Is it enabled in Settings - Server - Transcoder - Show Advanced
- Is this a new container which needs mapping to the physical /dev/dri directory again ?
Having a look at portainer it does appear Dev/dri is not mapped.
Lemme see if I can fix it
May I ask the stupid question?
Do you have a specific reason to use Docker on the host?
If not, why not run the native installer?
An entirely new installer is being released and is much more intelligent and well behaved that its predecessor.
I have a forum preview of it with 1.17.0.1812 currently available for folks to look and try if so desired
It’s the way I have it all setup atm.
Way too many dependencies and automation to change atm . Might do it at a later time .
But thanks for the suggestion
Ok.
Updates would be available, automated, via the repository and normal OS updates so that much will be removed from your “to do” list.
