HW transcoding not working
Server Version#: Plex Media Server v1.41.4.9399
Player Version#: Web Version 4.144.1 - other players have same issue
Windows Server 2025 OS
CPU: Intel i7 8700 - iGPU HD 630 for transcoding
HW transcoding seems to fail in both 1.41.4.XXXX beta versions.
When i roll back to 1.41.3.9314 HW transcoding works again.
I have tried enabling & disabling the new HEVC transcoding, no difference.
iGPU drivers have been updated.
Logs at the time of the crash below. & zip attached
Plex Media Server Logs_2025-01-23_19-41-14.zip (388.5 KB)
If there is anything more i can do, let me know.
Jan 23, 2025 19:35:08.258 [25272] ERROR - [Req#2bd/Transcode/ceyr0vsylitsd024mk2lf7da/adc6929a-1513-4f90-a070-7f996ddfd4d0] [AVHWFramesContext @ 000001aac4fb7ec0] Could not create the texture (8007000e)
Jan 23, 2025 19:35:08.258 [25272] ERROR - [Req#2c4/Transcode/ceyr0vsylitsd024mk2lf7da/adc6929a-1513-4f90-a070-7f996ddfd4d0] [h264 @ 000001aac082da40] Failed setup for format d3d11: hwaccel initialisation returned error.
Jan 23, 2025 19:35:08.292 [23368] ERROR - [Req#2c5/Transcode/ceyr0vsylitsd024mk2lf7da/adc6929a-1513-4f90-a070-7f996ddfd4d0] [AVHWFramesContext @ 000001aac8fdb180] The hardware pixel format ‘yuv420p’ is not supported by the device type ‘QSV’
Jan 23, 2025 19:35:08.292 [23368] ERROR - [Req#2c6/Transcode/ceyr0vsylitsd024mk2lf7da/adc6929a-1513-4f90-a070-7f996ddfd4d0] [Parsed_hwmap_0 @ 000001aac51aef00] Failed to create frame context for reverse mapping: -40.
Jan 23, 2025 19:35:08.292 [23368] ERROR - [Req#2c7/Transcode/ceyr0vsylitsd024mk2lf7da/adc6929a-1513-4f90-a070-7f996ddfd4d0] [Parsed_hwmap_0 @ 000001aac51aef00] Failed to configure output pad on Parsed_hwmap_0
Jan 23, 2025 19:35:08.294 [23368] ERROR - [Req#2c8/Transcode/ceyr0vsylitsd024mk2lf7da/adc6929a-1513-4f90-a070-7f996ddfd4d0] Error reinitializing filters!
Jan 23, 2025 19:35:08.294 [23368] ERROR - [Req#2c9/Transcode/ceyr0vsylitsd024mk2lf7da/adc6929a-1513-4f90-a070-7f996ddfd4d0] Failed to inject frame into filter network: Function not implemented
Jan 23, 2025 19:35:08.294 [23368] ERROR - [Req#2ca/Transcode/ceyr0vsylitsd024mk2lf7da/adc6929a-1513-4f90-a070-7f996ddfd4d0] Error while processing the decoded data for stream #0:0
Were you able to solve this? I’m running into the same issues. I’ve been messing with it all day.
I rolled back to the public 1.41.3.XXXX release. I have no issues on that one. HEVC & H264 transcoding works on that one as well.
Not sure if Plex devs are aware, but i’m just gonna test the new versions when they release.
Thanks! That fixed me right up.
