I cannot fix a match
Server Version#:1.24.1.4931
Player Version#:4.63.3
I cannot get Plex to recognize the series “Cinéastes de notre temps”
I created a folder, in which I placed the files I have, naming them as indicated in Cinéastes de notre temps - TheTVDB.com
S1964E01 Luis Buñuel.avi
S1964E03 Jean Vigo.avi
S1964E03 Jean Vigo.es.srt
S1965E01 Carl Th. Dreyer.avi
S1966E01 Le celluloïd et le marbre.mp4
But I can’t get Plex to recognize either series of episodes. Can you please help me? Thanks a lot.
You are using the new tv show agent, right?
There is no tv show on TMDB by that name. Instead, all the episodes are appearing as separate movies. cinéastes de notre temps — The Movie Database (TMDB)
Hi, thanks for your answer.
What is the new tv show agent?
I was told to use thetvdb.com as a guide. The show appears there and there are codes for each episode, but, as I have already told you, to no effect.
When you edit your TV shows library,
go to the “Advanced” tab.
If it says “Plex TV Series” under Agent, you are using the new agent.
If it says “TheTVDB”, you are using the old agent.
If you are still on the old agent, use Fix Match and then type in the ID of this show 381232 into the “Title” field. (Clear out the “Year” field.)
If you are already in the new agent, there is currently no solution, except adding each episode as a movie, into a movie library.
Hi, Otto,
Thanks for your kind answer.
As always, you were very kind.
I will, then, put back the three episodes as independent movies.
Best regards,
