Server Version#: 1.25.2.5319
I’m trying to get Plex to recognise a show that is present in TVDB but not in TMDB (using the Plex TV Series agent). When selecting Fix Match I was usually able to enter a TVDB ID, but that doesn’t seem to work anymore. Looking in the support docs I see this:
- If you are using the “Plex TV Series” agent, you can optionally include the TMDB or TVDB show ID in the folder name to improve matching. If you choose to do that, it must be inside curly braces:
ShowName (2020) {tvdb-123456}orShowName (2020) {tmdb-123456}where123456is the show ID. An example can be found at the end of the article.
Tried it as wel (Jiskefet (1990) {tvdb-83658})l, but does not work. What am I doing wrong?
