I cannot get a direct connection with my server
Server Version#:
I cannot seem to directly connect to my server on Plex. My Shield tv and my computer are connected via ethernet to the same network but I keep getting a message on my Shield that it is indirectly connected and as a result nothing will play in HD. Can someone help me with this? What are the settings for my PC server that I should turn on, off or set to?
Check the Ethernet settings on the PC. Make sure it is configured as a private, not public, network.
In Windows 10: Settings → Network & Internet → Properties
Ooooh thank you so much! That worked! Yayyyy!!! Thanks so much FordGuy61!
So easy, thank you)
