I have Plex Pass. What settings do I need to use to make Plex use only my locally stored trailers?
It seems like no matter what settings I change or what Agents I mess with, Plex continues to pull external trailers. I’m trying to test something with my local trailers, and I can’t do that without being able to force only those trailers.
Can anyone help me out?
Admittedly a SWAG, but have you tried editing a library, click on advanced, de-select “Find extras & trailers automatically.” You might have to refresh library metadata to get rid of any existing links to online trailers, etc.
Same setting is also in the Plex Movie agent in Settings -> Agents.
Hmmm, I’ve done that in my agents tab but never thought to try in the library edits. I’ll give it a shot, thanks dude
Update: Looks like those options were already unchecked, so no change there. I appreciate the suggestion though
After making those configuration changes, you need to Refresh Metadata of the movie where you want to test it.
Of the movie that I want the trailer to play in front of, or the movie that it’s named for and stored with?
The latter.
Alright I got it working. Thanks everyone for all your help. Now I’m able to download my own current trailers and have those play instead of trailers for movies that are actually in my own library, or the same 5 trailers that Plex plays on shuffle.
What I ended up having to do was:
  1. Disable all settings for automatic trailers in the Extras settings, Plex movie agent, and the movie library advanced settings
  2. Download YouTube playlists of trailers (easiest way to get a large number for me)
  3. Rename the trailers to match a movie in your library using the MovieName Trailer#1.mp4 format
  4. The subdirectories were kind of tricky. You have to use the Plex subdirectory format, except your 2nd folder in cannot contain the year in the title. So it would look kind of like:
\Movies
\MovieName
\Movie Name 2018
MovieName.mkv
\Trailers
Then refresh the metadata for all the movies you added trailers to, restart PMS just to be safe, and now the new trailers should play
