Hello. New to these forums, so I hope that I am posting this in the right location. Seems right. Anyways.
I have been using Plex on my home network for a few months and haven’t had had any real playback issues, but I have noticed 3 different but related issues, all concerning metadata.
Reaper
This show has proper metadata for season 1, but season 2 is flat wrong. Despite detecting the correct season, episode number, and particular episode’s synopsis, the server names every single second season episode as “S1 E17 The Leak”…which is a season 1 episode, clearly. I’ve watched the show, so I’m not terribly worried about this one, just pointing it out.
Cannot properly detect/handle multiple related series in one folder
Per my personal conventions developed over the years, I prefer to have one folder dedicated to the overall series and the various particulars available in subfolders from there. As an example, my preferred layout for Sonic the Hedgehog shows follows, but others include Gundam and American Horror Story and seem subject to the same improper reading.
- Sonic the Hedgehog
- [1] Adventures of Sonic the Hedgehog
- [2] Sonic the Hedgehog (SatAM)
- [3] Sonic Underground
- etc
When nested as above, it will seem to think that the whole thing is one show, making it basically impossible to watch anything in order, nor can you find a particular episode or show based on metadata because it’s just haphazard. In these instances, this can be resolved by moving a nested folder out to the root of the watched folder.
- etc
Super Sentai
I’ve not yet had the opportunity to rip Zyuranger or Dairanger (seasons 17 and 18…DVDs on the way!) I do have Abaranger available (season 27) and initially tried my nested folder scheme as above. (Super Sentai > [27] Bakuryuu Sentai Abaranger). It detected and displayed the show as season 1, the original Super Sentai! Figuring it might be related to having just the one folder in there, I moved it out to the root, and removed the [27]. Oddly enough, it still is detected as Season 1. All of these are properly named files, if that affects anything (ex, Bakuryuu Sentai Abaranger - 01 - Abare Dinosaur Big Charge!.mkv).
Companion movies not detected with show
This one sorta makes sense, but is still annoying. When a movie is placed with a related series (let’s say Firefly+Serenity), it isn’t detected with the rest of the show, from the show’s location. Other extra features are also not detected in this way, either. Is there so way to force an entry to recognize a particular file?
Whew.
Is there a way from within Plex to manually set a folder’s intended show? I think this would solve most of the above problems while preserving my sensibilities - clearly, the most important issue here.
Thanks in advance!
—Qriist
