Identify movies
Server Version#: 4.108.0
Hello,
I can’t identify certain movies. Why aren’t these found?
I ask for help.
Those aren’t movies but tv shows (listed as „mini series“). Accordingly you should add them to a tv-show type library…
Thanks for your answer. Still doesn’t work. The folders are shown as empty.
How did you name/organize those „missing“ files?
The series consists of two parts. They are summarized in one file.
How have you named that file?
Should be something like
TV Shows  <- the folder linked to your tv-show library
  Bag of Bones (2011)
    Season 01
      Bag of Bones (2011) - s01e01-e02.ext
Where .ext is a placeholder for your file extension.
Thank you very much, it works.
Just fyi, you might want to check out the episodes of “Spartacus Gods of the Arena”
That is actually part of the show Spartacus which has 4 seasons. Gods of the Arena is listed as a special season of that show
https://thetvdb.com/series/spartacus/seasons/official/0
It looks like the TMDB is not matching things correctly. There’s mismatched and missing episode info
I would set to use the TVDB order.
Click the pencil on the show poster → Advanced → Episode ordering → TheTVDB (Aired)
Those episodes need to be in a Season 00 folder named like this
Screenshot (1785)
Then…
3 dots next to the library → Manage Library → Edit → Advanced
Tick “Use season titles” and they will display like this
Screenshot (1793)
