I would like to see an editable IMDB link included so when a title is mismatched it is easy to get the correct metadata and cast updated to the correct ones, by adding the correct link.
Is this feasible?
Is this feasible?
You should edit the IMDB link on the agent site supplying the metadata. (TVDB or TMDB). It will eventually make it into Plex’s cache.
There’s not a link to IMDB, but there are a couple of ways you can use the IMDB “tt” number to ensure a correct match:
Include the tt number in the filename:
https://support.plex.tv/articles/naming-and-organizing-your-movie-media-files/#toc-0
Use the tt number to match (See “Tips” at the bottom of the page):
https://support.plex.tv/articles/201018497-fix-match-match/
