[Implemented] Auto-skip show intros
It would be lovely to be able to manually turn on & configure (per series) the ability to auto-skip a show's intro/recap.
Primarily for TV series from FX, HBO, Showtime, AMC. For ex: Boardwalk Empire has a 1:30 intro. Sons of Anarchy, The Americans, tend to have recap + intro. The Walking Dead has recap + intro.
I expect the ability to manually opt into & configure this feature would likely be a necessity, considering users source their media from all sorts of locations, whether from a PVR/DVR, DVD, Blu-ray, etc.
I'd propose a server-side configuration for series, with ability to override/ignore such settings on the client-side.
Problem with this is that quite often there's the short 'catch up' things before the intro, which tend to vary in length.
However I agree, it would be an awesome feature.
Which is why it would need to be individually opted into & configured. Agreed the catchup/recaps aren't always of dependable lengths.
A more complex solution (but also possibly more accurate) would be to provide an audio/video snippet of the intro, so then a scanner could identify it's location in each video, and set start point per-episode to coincide with the end of that snippet.
Wouldn't work for shows that have a delayed intro (new content prepended to intro).
** Would likely need to support multiple snippets, for shows that change intros throughout seasons
Another option would be to have Plex play the episode, excluding the points identified by a snippet. So then you'd get the variable-length recap and any new content, but the intro itself would be skipped. Rather than editing video, it would instead function like an auto-fast-forward that is triggered by an event (reaching X timestamp).
If a scanner option isn't possible, these are some ideas I came up with, not sure how feasible they are:
1. For each show on the server side, you can enter a second amount that you want to skip. (10, 15, 30, 60, x seconds). Would be an option that either pops up when you choose to play multiple episodes of the same series, or an option in the main PHT settings.
2. A crowdsourced database, by Plex users for Plex users type of deal. Where users can enter a Show and then the amount of time to skip for a series (where it can be overridden for episodes if needed).
Maybe the time limits of the Into could be reteive from the subs?
Feature has been implemented and is now available to Plex Pass members.
https://www.plex.tv/blog/go-ahead-and-skip-that-intro/
https://support.plex.tv/articles/skip-content/
