Import/Export Live TV & DVR Channel Mappings
Is there a way to export and then import the DVR channel mappings? I am finding little problems due to some changes in my Tuner, but it is too tedious to do in the UI. i.e., the listings are literally hundreds of mapping choices and it takes forever.
I presume these could and are surfaced somewhere as an XML file, but I can’t seem to find it.
AFAIK, there’s currently no such 3rd. Party nor native solution
And it’s not stored in an xml, but created on the fly from the database
When said, it’s on the roadmap for WebTools-NG, just haven’t got the time yet to make it :wink:
Got it! Glad it is on someone’s list. There are many reasons to redo your Channel lists. I’ve gone through it about 8 times myself. So this would be a huge timesaver!
I did it when I had to fix my tuner and move between Server boxes. Also, with the volatility of IPTV services, that one would be my main use-case. I’ve literally spent several hours getting my latest one working. I just found out that when I change the number of tuners, I have to delete and re-run it all over again.
