Can’t find dvr in settings
Are you on the server settings?
@donmclain
Strange issue, not sure which version you have but I just checked my server(s) and 1.6.1 doesn’t have live & Dvr option (well in this version it was dvr beta) but its gone funny thing is the programming guide and recording schedule are there and its still recording my shows . On version 1.8.x its Live & Dvr under the settings menu and thats present and working . not sure what the deal is but I see same issue you are on 1.6.1 . Last time I saw something like this happen is when it doesn’t think you have a DVR Recorder hooked up or defined, but strange part like I said is its recording stuff using my dvr(s) on 1.6.1 did you try stopping and starting your plex instance… I can’t do that at the moment since its recording stuff and won’t finish till around 1am but will restart as soon as I can to see if it restores the option on the settings menu.
I noticed this with the last few web releases. Just haven’t had time to verify to report as a bug but it appears if you go via the web (app.plex.tv) you no longer get DVR & Live TV in the Settings page. However if I go via local (IP address:32400) DVR & Live TV shows up. I’m running PMS 1.5.5 and using Safari 10.1.2.
I noticed that they “Fixed DVR settings page styling in Safari” under Plex Web 3.20.3. That’s when this bug popped up for me.
