Incorrect TV show poster persisting
Pick one of the other selections FileBot offered - 'cause with so many to chose from - it offered a selection - and you picked the wrong one.
You mean it simply does not match. The first link you provided previously completely solved the issue, thanks. I now recognise that searching via the Plex Match option has limitations!
plex matched based on the folder/filename, so if the folder/filename is not correct (or not very close) then it will of course match incorrectly.
naming the series properly, will almost always get you the correct metadata (or at least as correct as plex’s metadata providers have).
soooo, if you want plex to provide the proper posters/art, then you must name them according to the correct tvdb show.
in this case, it is @ https://www.thetvdb.com/series/blackadder/seasons/4
And you can always get the match you want by going the route I posted earlier.
