Indexing of my mp3 Files does not work !?
Server Version#:Plex Media Server v1.31.3.6868-28fc46b27 - Debian GNU/Linux PC aarch64 - build: linux-aarch64 debian
First … hi all and thanks for your time.
I installed plex media Server on my Raspberry3B+.
Everything (Installation etc. works fine.
Adding my Media (Musik) works fine too.
When the server starts to index my Media (and when i try to generate them new), it seems that everything works fine too but, then tht following happens:
Mar 31, 2023 14:23:17.824 [0x7f8d8be0c8] Fehlersuche — Done with metadata update for 454
Mar 31, 2023 14:23:17.842 [0x7f8d8be0c8] Fehlersuche — Loaded metadata for Satellit (ID 455) in 11ms
Mar 31, 2023 14:23:17.844 [0x7f8d8be0c8] Fehlersuche — Done with metadata update for 455
Mar 31, 2023 14:23:17.862 [0x7f8d8be0c8] Fehlersuche — Loaded metadata for Systemstörung (ID 456) in 10ms
Mar 31, 2023 14:23:17.864 [0x7f8d8be0c8] Fehlersuche — Done with metadata update for 456
Mar 31, 2023 14:23:17.882 [0x7f8d8be0c8] Fehlersuche — Loaded metadata for Trümmergemüt (ID 457) in 10ms
Mar 31, 2023 14:23:17.885 [0x7f8d8be0c8] Fehlersuche — Done with metadata update for 457
Mar 31, 2023 14:23:17.902 [0x7f8d8be0c8] Fehlersuche — Loaded metadata for Ungeschützte Räume (ID 458) in 10ms
Mar 31, 2023 14:23:17.904 [0x7f8d8be0c8] Fehlersuche — Done with metadata update for 458
Mar 31, 2023 14:23:17.922 [0x7f8d8be0c8] Fehlersuche — Loaded metadata for Everlong (ID 459) in 10ms
Mar 31, 2023 14:23:17.924 [0x7f8d8be0c8] Fehlersuche — Done with metadata update for 459
Mar 31, 2023 14:23:17.942 [0x7f8d8be0c8] Fehlersuche — Loaded metadata for Amen Yves (White Circles) (ID 460) in 10ms
Mar 31, 2023 14:23:17.944 [0x7f8d8be0c8] Fehlersuche — Done with metadata update for 460
Mar 31, 2023 14:23:17.963 [0x7f8d8be0c8] Fehlersuche — Loaded metadata for Sabres (ID 461) in 11ms
Mar 31, 2023 14:23:17.964 [0x7f8d8be0c8] Fehlersuche — Done with metadata update for 461
and so on (every Metadata in 10-11ms?!)
the directory with the files is 777 and user:group is plex:plex.
Well right now i saw that:
ZeitstempelMar 31, 2023 14:47:49.217
LevelWarnung
Thread0x7f7dfbb0c8
Nachricht[CERT] TLS connection from [::ffff:192.168.8.100]:19159 came in with unrecognized plex.direct SNI name ‘192-168-8-104.6951cd7ac98c446aa4dc6cb70ca5b607.plex.direct’; using installed plex.direct cert
No idea if that is important
Regards Chris
Problems solved.
I had to change the Agent to “Last FM” and now it works :slight_smile:
