Wie alt ist die Installation?
Hast du viele 3rd party Channels/MetadatenAgenten/Scanner nachinstalliert?
Es gibt anscheinend Probleme mit dem Plug-ins Verzeichnis.
2015-08-31 14:46:55,191 (8d8) : ERROR (networking:217) - Error opening URL 'http://127.0.0.1:32400/:/plugins/com.plexapp.system/resourceHashes'
2015-08-31 14:46:55,194 (8d8) : CRITICAL (core:572) - Exception getting hosted resource hashes (most recent call last):
File "bundles-release/Framework.bundle-dist/Contents/Resources/Versions/2/Python/Framework/components/runtime.py", line 1287, in get_resource_hashes
File "bundles-release/Framework.bundle-dist/Contents/Resources/Versions/2/Python/Framework/components/networking.py", line 263, in content
File "bundles-release/Framework.bundle-dist/Contents/Resources/Versions/2/Python/Framework/components/networking.py", line 241, in __str__
File "bundles-release/Framework.bundle-dist/Contents/Resources/Versions/2/Python/Framework/components/networking.py", line 181, in load
File "C:\Program Files (x86)\Plex\Plex Media Server\python27.zip\urllib2.py", line 410, in open
response = meth(req, response)
File "C:\Program Files (x86)\Plex\Plex Media Server\python27.zip\urllib2.py", line 523, in http_response
'http', request, response, code, msg, hdrs)
File "C:\Program Files (x86)\Plex\Plex Media Server\python27.zip\urllib2.py", line 448, in error
return self._call_chain(*args)
File "C:\Program Files (x86)\Plex\Plex Media Server\python27.zip\urllib2.py", line 382, in _call_chain
result = func(*args)
File "C:\Program Files (x86)\Plex\Plex Media Server\python27.zip\urllib2.py", line 531, in http_error_default
raise HTTPError(req.get_full_url(), code, msg, hdrs, fp)
HTTPError: HTTP Error 404: Not Found
Mein erster Vorschlag wäre: saubere Deinstallation. Ausräumen des Plug-ins Verzeichnisses im Plex Datenordner.
Achtung: mache eine Liste, welche Channels und zusätzlichen Metadatenagenten du installiert hattest. Bitte nutze die Gelegenheit, da mal aufzuräumen und nur die wirklich genutzten Sachen zu behalten.
Nachtrag: Es könnte auch eine Spezialität von Win Server sein, wo die Firewall selbst den Zugriff auf 127.0.0.1 (localhost) beschränkt. Leider habe ich von Windows Server nicht wirklich Ahnung.
Nachtag zum Nachtrag: zieh dir das mal rein: https://forums.plex.tv/discussion/175436/plex-server-on-windows-server-2012-r2-standard
