Server Version#: 1.40.5.8854
Player Version#: 3.0.3-2421.0001
Trying to watch on a new Vizio TV and the connection is indirect, I can only play media via relay in SD with an absolutely throttled bitrate. Every other device in the house (ios, laptop, and Roku TVs) has no problem with a direct connection, so it’s not a router issue. Desktop that hosts the server is connected to the LAN, TV which is 3 feet away is connected to the Wi-Fi and the router is in the same room. The problem persists when the desktop is connected to Wi-Fi as well. No settings I’ve changed on the server have made any change: manually assigning a public port or not, setting and removing an upload speed cap, changing between requiring secure connections and not, turning on and off VPN, checking and unchecking “treat WAN IP as LAN”, enabling and disabling relay, adding the TV’s IP address to the “LAN networks” list…I don’t know what else to try to establish a direct connection.
