Individual TV Episode Extras missing?
Unless I missed something in the new beta, while there are extras for a TV show as a whole, the individual episodes now have no way to access their extras. I can only hope this is an easily corrected mistake.
Anyone know something about it I don’t?
I am pretty sure they are still there, it was one of the first thing I checked as I have spent years adding these and they don’t seem to be supported by Plezy or Plex via Kodi.
I will double check this evening.
I don’t normally have episode extras, but created one to test and it shows up on the beta Android app, the tvOS beta and the current Fire app. (All are essentially the same app now) when you move over the episode the extras show up below.
Nothing existing shows up on mine. I haven’t tried making anything new.
I just checked… episode extras show up under the selected episode. That’s way under it… below cast & crew, and ratings & reviews you should find the trailers & extras hub with all episode extras.
Similarly, you should be able to see and access season specific ones by selecting the “season tile” at the very left of the episode list.
