Display tv-show extras for shows, seasons and episodes in all apps
I am a recent convert from Emby to Plex. I like how Plex groups the extras by the sub-folders (ex: Behind The Scenes, Deleted Scenes, etc.) But, there is still an issue with TV extras that I found after ripping all of The Office (2005) with all of the extras. I went through and named each and put each extra in the correct folder. The issue arises because there’s 188 episodes with almost every ep has an associated deleted scene. So, for me to get to any extra other than Deleted Scene (or one in a later season), I have hold the right scroll through 180 some videos until I finally get to the next group of extras.
It would be nice if we could scope extras to an episode or at least to a season. It might be an easier quick win to scope to a season since seasons already have folders and could easily add sub-folders for the extras. So, if you are on a specific season or specific episode, it would show you just those extras. The less specific the item show > season > episode, the more extras you would see and have to scroll through. The UI seems like it could easily accommodate this.
You can already do that.
The only downside is that as of today only a few apps are able to present local extras for tv series based content.
Client Show Season Episode
Android (mobile),
iOS,
Roku,
Apple TV (new experience preview)
:white_check_mark: :white_check_mark: :white_check_mark:
Android (mobile),
iOS
LEGACY
Plex HTPC,
WebTV Clients (*)
separate hub on episode level
:white_check_mark:
Roku
LEGACY
:white_check_mark: :white_check_mark: :white_circle:
Android TV,
Apple TV
:white_check_mark: :white_circle: :white_check_mark:
Plex Web,
Plex for Mac/Windows/Linux
:white_check_mark: :white_circle: :white_circle:
[Edit: updated table to reflect that Android TV now also supports episode-level extras – thanks for pointing this out, @zagreus360 ]
[Edit 2: updated table to reflect that Roku clients now also support season-level extras – thanks for pointing this out, @Red5ive ]
[Edit 3: Plex HTPC and “WebTV clients” (*) adding support for season/episode level extras → Plex HTPC 1.29.1, Plex for Xbox 2.107.1, Plex for Playstation 5 / Playstation 4 / VIZIO SmartCast / Plex for Samsung Tizen / Plex for WebOS 3+ / VIDAA (Hisense televisions) version 5.50.1]
For season tier extras you can apply all the same structures you know from tv-show tier extras.
For episodes the naming is a little trickier / more restricted as Plex only supports inline extras, no subfolders.
Example:
TV Shows   <- folder linked to the tv-show library
  Show Name
    Season 01
      Show Name - s01e01 - blahblah.ext
      Show Name - s01e01 - blahblah-featurette.ext
      Show Name - s01e01 - blahblah-deleted1.ext
      Show Name - s01e01 - blahblah-deleted2.ext
      Show Name - s01e01 - blahblah-deleted3.ext
Where .ext is a placeholder for the respective file extensions.
The base name of the local extra must match the expisode name to the letter.
There’s another feature suggestion asking for an option to allow episode-level extras to be added via subfolders too in order to allow custom names/titles for those.
Ok, when I read that on the naming convention page, I thought that was just a way to do the extras if you didn’t want to create folders. I will try that. Unfortunately, I am not using Android Mobile or iOS, I am using Roku. So, if I implement either the season specific or episode specific extras, will it show up as one giant collection of extras under the show as it does now?
Apps will simply ignore extra tiers they don’t support
Crap. Not quite sure what to do then. I wouldn’t mind doing the grunt work for all three if it didn’t mean duplicating files, which for The Office itself is 1.4TB. I guess my request would be that if named correctly, ex: S01E01 - The Pilot, file being in the Deleted Scenes subfolder of The Office (2005), then when you click on the Show, it shows up in the extras under Deleted Scenes, then if you clicked on Season 1, it would also be there, and if you clicked on Episode 1, it would also show up. But, on Season 2, or any other episode, it would not show. Should I create a new post for this as it seems to be a bit different of a request?
So, I attempted a couple different things. I tried the season level extras folder and the episode specific folder with extras folder inside. I rescanned my library. I don’t see the extras when I click on a season or an episode, which is expected since I’m looking at it on a windows Plex server and Roku, which do not support this yet. But, surprisingly, it still shows the extras that I moved into season and episode folders, at the show level.
I just checked it on my phone (Android mobile) and it is not showing season or episode specific extras. So, there must be something wrong that the scan is not picking up my changes.
You need to refresh the metadata for Plex to pick up changes to the local extras.
Ok, that did work. I am able to see the changes scoped to the season now on Android. But, since it just removes them all on the Roku (I don’t watch on my phone), I’ll just undo it until it comes to Roku and the naming convention is solidified. Hopefully, they do folders for episode local extras.
Let’s adjust the title to reflect the actual gap → done
Android TV’s now showing episode extras for me
No surprise… see the current support summary/matrix from above:
Am I looking at a different chart? That chart only shows show level for extras not episode level
My bad… I misread your post as “Android TV’s not showing episode extras for me”
Edit: you’re right… I can see my episode-level extras on Android TV too :smiley:
Any update on getting season and episode extras evened out between all clients? Mostly interested in macOS and Apple TV clients.
Ditto on the AppleTV Season level extras. Almost all of my extras are organized by Season so unfortunately none of them show up in the ATV app.
I would like to add support for completing this feature. It’s been well over a year since the TV agent/scanner came out of beta. Most of my shows contain specials at the season level, and I prefer to watch using a TV platform.
Additionally, it would be great if specials could be edited just like any other item with the ability to change poster (I know titles can now be changed within the file), etc. It would be great if specials also showed up in Continue Watching and stayed regardless of other items within that show. For example, The Office has deleted scenes for several episodes together. Previously, I would tack these on to the end of a season, so I would watch ep 1, then part of ep 101(deleted scenes), but starting 101, would eliminate ep 2 from Continue Watching. The way it works now is better, though I have to stuff all season extras on the show level, so it is quite a lot of scrolling.
One more thing…If there are extras, I’d like to see that appear above the cast, not below. At the very least let that be an option. I have some extended episodes as Extras-other that I missed because I didn’t see the extra. Though I supposes I could make the extended ep the main title and originally aired the extra.
There’s an app for that… I mean another feature suggestion :wink:
And another one :wink:
Thanks. I only have one vote left…I feel like that meme.
Same here…been waiting on tv show extras for years. I don’t watch too much on my little phone screen so extras on the phone app doesn’t make sense to me before actual tv apps like the Apple TV application. Bumping but also know it’s been so long I doubt they are going to add feature parity.
