Infinite spinning circle
Server Version#: Version 1.32.2.7100 ??
Player Version#: Android (TV) 9.21.2.1271
On /settings/web/general page I can see this: Version 4.100.1
Just updated to the latest Plex server, now trying to watch on my tv, Films gone, TV gone, Music gone. All I get is a spinning circle for the rest of eternity. No errors, no time outs just infinite spinning circle…
I’ve re-linked the tv using https://www.plex.tv/link/ and I can see there is an /!\ in a triangle next to my user icon.
I really hope this doesn’t happen every time I do an update, there must be an easier way…
which distro?
Which CPU are you using?
Everything was fine until the latest update.
Plex server is running in a Docker Container in an LXC on Proxmox. X64 cpu.
Completely fine when viewing from my laptop, it’s just the TV app that no longer seems to work
Humm, it seems as though there are problems with https://app.plex.tv/desktop/ as well now. I wish I hadn’t updated :frowning:
Everything completely fine locally from my laptop, ie
https://plex.mydomain.com
@Muttley-do-something
What’s the CPU ? (specific SKU)
‘x64’ is the instruction set, not the CPU SKU ( e.g i7-7700 )
You say “app”.
Player APP or server itself ???
FYI, If you’re running a LXC on ProxMox, you don’t need the added BS of a Docker container. It adds yet another layer of abstraction and something to fail.
I am running multiple media programs in docker containers, all those containers are on one LXC that I can back up with ease. The problem is not Proxmox, nor my network config.
Everything was absolutely fine - right up until I ‘updated’ plex server.
FYI, If I were to follow your ‘instructions’ I would need multiple LAN IP’s, multiple RAM reservations and the entire network would be a lot more messy as well as consume more system resources. You might want to look into the benefits of Portainer
thanks for clarifying. Now it all makes sense.
In docker, you can pull any version you wish.
e.g.
plexinc/pms-docker:1.29.2.6364-6d72b0cf6
Let me know if you need the build hash code to add to the version.
Will do, thanks :smiley:
FYI.
If you’re using PMS-docker, you can also get onto the docker command line and install any version you want using dpkg -i filename.deb
I can give you whichever you need.
Maybe this one? :smiling_imp:
