Inherit Discover Extras in Library
When I search a show in discover it is often populated with various online extras and trailers. I would like to enable a way for these online extras to be displayed in the same way when the show is selected from my server library.
Please let me know if my message is unclear and needs to be reworded or enhanced.
AFAIK they already should, assuming your library is matched using Plex TV Series agent .
As BigWheel wrote – those “extras” are usually based on TheMovieDatabase’s episode ordering. TMDb allows adding tons of what Plex considers “extras” into their Specials season. TVDb on the other hand is more strict and only allows actual specials (e.g. special episodes aired outside of regular seasons).
Here’s an example to complement BigWheel’s “Black Sails” reference:
Personally I prefer treating extras as actual extras (see lower half of BigWheel’s screenshots) :wink:
Thank you both very much for your reply. As you suggested my agent was the issue.
Once I switched to the Plex TV Series agent and refreshed the library, everything populated just as I wanted.
Thanks again and I do apologize for the bother.
