Installation has errors don't understand, pls help fix
Server Version#:latest both
Player Version#:latest both
(Reading database …
(Reading database … 5%%
(Reading database … 10%%
(Reading database … 15%%
(Reading database … 20%%
(Reading database … 25%%
(Reading database … 30%%
(Reading database … 35%%
(Reading database … 40%%
(Reading database … 45%%
(Reading database … 50%%
(Reading database … 55%%
(Reading database … 60%%
(Reading database … 65%%
(Reading database … 70%%
(Reading database … 75%%
(Reading database … 80%%
(Reading database … 85%%
(Reading database … 90%%
(Reading database … 95%%
(Reading database … 100%%
(Reading database … 1084489 files and directories currently installed.)
Preparing to unpack …/plexmediaserver_1.43.1.10611-1e34174b1_amd64.deb …
Failed to stop plexmediaserver.service: Unit plexmediaserver.service not loaded.
PlexMediaServer install: Pre-installation Validation.
PlexMediaServer install: Pre-installation Validation complete.
Unpacking plexmediaserver (1.43.1.10611-1e34174b1) over (1.43.1.10611-1e34174b1) …
Setting up plexmediaserver (1.43.1.10611-1e34174b1) …
PlexMediaServer install: PlexMediaServer-1.43.1.10611-1e34174b1 - Installation starting.
PlexMediaServer install: Now installing based on:
PlexMediaServer install: Installation Type: New
PlexMediaServer install: Process Control: systemd
PlexMediaServer install: Plex User: plex
PlexMediaServer install: Plex Group: plex
PlexMediaServer install: Video Group: render
PlexMediaServer install: Metadata Dir: /var/lib/plexmediaserver/Library/Application Support
PlexMediaServer install: Temp Directory: /tmp
PlexMediaServer install: Lang Encoding: en_US.UTF-8
PlexMediaServer install: Processor: AMD Ryzen 7 1700X Eight-Core Processor
PlexMediaServer install: Intel i915 Hardware: Not found
PlexMediaServer install: Nvidia GPU card: Found
PlexMediaServer install: Completing final configuration.
useradd: group plex exists - if you want to add this user to that group, use -g.
PlexMediaServer install: ERROR: Cannot create user “plex”. Error: 0
groups: plex: no such user
usermod: user ‘plex’ does not exist
PlexMediaServer install: ERROR: Cannot add ‘plex’ to video group ‘render’. Error: 0
PlexMediaServer install: WARNING: Could not add ‘plex’ to video group ‘video’. Error 0
PlexMediaServer install: Plex Media Server: ver PlexMediaServer-1.43.1.10611-1e34174b1 - Installation failed. Final configuration not performed.
PlexMediaServer install: Assistance is available in our Support Forums.
PlexMediaServer install: both
dpkg: error processing package plexmediaserver (–install):
installed plexmediaserver package post-installation script subprocess returned error exit status 255
Processing triggers for mailcap (3.70+nmu1ubuntu1) …
Processing triggers for gnome-menus (3.36.0-1.1ubuntu3) …
Processing triggers for mate-menus (1.26.1+mint1) …
Processing triggers for desktop-file-utils (0.27-2build1) …
Errors were encountered while processing:
plexmediaserver
this is the log, sorry, old veteran raising grandkids and i just can’t get anything to work. Let me know what to do thank you so much ahead of time. thanks don
Are you using linux Mint?
