I saw that there was an update so upgraded the server from 1.19.3.2737 to 2740 but after the server restarted, it still showed as 2732 in the PlexWeb. I went ahead and installed it again and the install log does show that it was installing 2740 over 2740 so it had upgraded but the UI still shows as2737. Also i noticed in the install log messages that Temp Directory is /tmp even though i have it configured to use /dev/shm. In the past, the install log would say something to the effect that the Temp Directory was overriden by the configuration. Looks like somethings not quite right with this linux build.
(Reading database ... 413347 files and directories currently installed.)
Preparing to unpack plexmediaserver_1.19.3.2740-add6f438d_amd64.deb ...
PlexMediaServer install: Pre-installation Validation.
PlexMediaServer install: Pre-installation Validation complete.
Unpacking plexmediaserver (1.19.3.2740-add6f438d) over (1.19.3.2740-add6f438d) ...
Setting up plexmediaserver (1.19.3.2740-add6f438d) ...
PlexMediaServer install: PlexMediaServer-1.19.3.2740-add6f438d - Installation starting.
PlexMediaServer install: Now installing based on:
PlexMediaServer install: Installation Type: Update
PlexMediaServer install: Process Control: systemd
PlexMediaServer install: Plex User: plex
PlexMediaServer install: Plex Group: plex
PlexMediaServer install: Video Group: video
PlexMediaServer install: Metadata Dir: /var/lib/plexmediaserver/Library/Application Support
PlexMediaServer install: Temp Directory: /tmp
PlexMediaServer install: Lang Encoding: en_US.UTF-8
PlexMediaServer install: Transcoding HW: Found
PlexMediaServer install: Completing final configuration.
PlexMediaServer install: Starting Plex Media Server.
PlexMediaServer install: PlexMediaServer-1.19.3.2740-add6f438d - Installation successful. Errors: 0, Warnings: 0
Processing triggers for libc-bin (2.27-3ubuntu1) ...
Processing triggers for bamfdaemon (0.5.3+18.04.20180207.2-0ubuntu1) ...
Rebuilding /usr/share/applications/bamf-2.index...
Processing triggers for gnome-menus (3.13.3-11ubuntu1.1) ...
Processing triggers for desktop-file-utils (0.23+linuxmint8) ...
Processing triggers for mime-support (3.60ubuntu1) ...
