Installed 1.20.0.3125 ... didn't get web player 4.34.4
Server Version#: 1.20.0.3125
Player Version#: 4.34.3
I installed the 1.20.0.3125 Plex server to try the new Plex Movie Agent, but I can’t update my libraries as my web player is still 4.34.3. First update was through the console, so I downloaded the exe from the site and the web player will not update… any way to force it?
https://app.plex.tv
Thanks!
@Daptonic The new bundled version (4.34.3) with the latest Plex server is sufficient for the new movie agent. If you’re seeing any specific issues with it please let me know.
@drzoidberg33 There is an issue specific to using 4.34.3 with the new agent. If you edit a library manually that uses the new agent the language options won’t appear correctly and select some arabian looking language if you hit save changes. This does not happen on the newer version. (I have two servers so that is how I access both GUI versions).
The notes specifically state the new agent requires 4.34.4. When I had 4.34.3 all my movie libraries failed to allow me to change to the new agent. After going to https://app.plex.tv it updated me to 4.38.2 and I was able to change the library to use the new Agent.
