HI,
I think I’ve installed the plex connect on my mac, fixed the IP address and can get it running in terminal. Where I had some issues was the certificate on the ATV 2 I’ve got which would get the error 109 while trying to add the apple.trailers.com/trailers.cer. With some searching, I got the certificate installed using my Plex server IP and port, and then when I look at my plex connect terminal window, it says:
00:30:48 WebServer: serving *.cer: /trailers.cer
So it appears to be working? However, when I click on trailers on the ATV, Apple’s trailers still show up and there is no plex??
I have 6.2.1 firmware on the ATV. If anyone can tell me where I might be going wrong, that would be great! THanks
