Need help....can't acess trailers ..unavalable ..try again later
Hi i need help with PlexConnect/AppleTV3
Software Apple TV 3 version: 6.1.1 (6698.99.19)
Python version:  2.7.X
Plexconnect version: 0.3.1
Plex Média Server version: 2.1.12
System Operacional: Windows 8
Meu Setting.cfg
[PlexConnect]
port_pms = 32400
port_webserver = 80
ip_plexconnect = 8.8.8.8
certfile = ./assets/certificates/trailers.pem
ip_dnsmaster = 189.7.0.52
loglevel = Normal
enable_dnsserver = True
logpath = .
ip_pms = 192.168.178.10
enable_plexgdm = True
hosttointercept = trailers.apple.com
port_ssl = 443
enable_webserver_ssl = True
prevent_atv_update = True
port_dnsserver = 53
enable_plexconnect_autodetect = True
What Happen?
When i try  received this message ...Trailers is unavailable try again later and doesn't work.
What's wrong?, can someone help?
i don't change any .cfg files....need it?
thanks
Looks like a cert issue to me. Delete all old certs on your aTV and PC (if they even exist) and Generate new certs and place them in your /PlexConnect/assets/certificates folder using this guide:
https://github.com/iBaa/PlexConnect/wiki/Install-Guide-Windows-Certificates
After your certs are in place stop your instance of plexconnect by pressing ctrl+c then start it back up again.
Then load your certs on your Apple TV via the network method using this guide:
https://github.com/iBaa/PlexConnect/wiki/Install-Guide-Certificate-via-Ethernet
Once thats complete restart your Apple TV, try your hijacked app and post your results. If that doesn’t work generate new certs and follow the above directions again.
