Just a quick suggestion. As the title says. Would it be possible to integrate a streaming speed test into the clients? A feature which transfers a packet of data from server to client and gives an approximation of the connection speed between the two. This could work for remote and local connections. It would be helpful to determine video settings in e.g. homeplug networks where speeds can vary based on distance etc. and aren't easy to predict, and might be better than trial and error playing with the settings. Just an idea.
This is a great idea as in my old house I find there is often variation in what my home plugs can handle - I'd love to see this integrated into the server so that any client can test the connection rate. Would also be fantastic when using the server from a remote location.
